Changing Blown Rear Strut Affects Toe Alot?
Changed out a blown rear driver side strut today on the girlfriend's s2k. It was another strut off the same yr car I found locally all assembled. So basically I just took out and replaced with the same oem strut. Did not disconnect sway bar or touch anything else, only the bottom strut bolt and top hats bolts were touched.
The car recently just got a full alignment done, my question is would changing this blow strut affect my toe so much that I would need to spend another 80 bucks on alignment? All steering seems fine just as before and ride height maintained since I did not lower the car.
Thanks!
Thanks!
sunnysd
04-18-2005 01:30 PM
