Challenge Coilovers?
I've been looking at numerous coilover setups, and came across the Challenge Comp and Comp+ from GTMotoring.
I have tried to call and inquire about them directly with GTM, but I have never had a call picked up, as well as no responses to my emails.....
Anyone have some info to help me out?
Comp
MSRP: $1450.00 intro special: FREE SHIPPING
Developed for both track and street driving, the COMP damper kit is a complete coilover suspension solution. The s2000 kit features mono-tube, steel, 16 level adjustable dampers that adjust rebound and compression simultaneously. Each kit includes full pillow ball upper mounts with aluminum mounting plates for optimal suspension response and durability. Damper bases are machined and argon gas welded steel with a gloss black powdercoat finish. Brand new OEM Honda nuts are included for mounting the bases to the lower control arms bolts. Top quality Hyperco 60mm racing coil springs in 10k in front and 10k in the rear are our default spec. Custom spring rates are available per customer request at no additional charge.
Comp +
MSRP: $1850.00 intro special: FREE SHIPPING
Developed with ultimate track performance in mind, the COMP + damper kit is a complete coilover suspension solution. The s2000 kit features mono-tube, aluminum 20 level adjustable dampers that adjust rebound and compression simultaneously. Each kit includes full pillow ball upper mounts with aluminum mounting plates for optimal suspension response and durability. Damper bases are machined aluminum with a gloss black powdercoat finish. This damper kit sees about a 50% weight reduction when compared to the Comp model. The aluminum damper also aids in efficient damper performance and heat dissipation while on track. Brand new OEM Honda nuts are included for mounting the bases to the lower control arms bolts. Top quality Hyperco 60mm racing coil springs in 10k in front and 10k in the rear are our default spec. Custom spring rates are available per customer request at no additional charge. We recommend 12k and 12k for heavy track use. This is the spec we run on our Time Attack cars with Bridgestone RE-11 tires.
Comp
Comp +
here is a link to a FS thread in the Marketplace about them
https://www.s2ki.com/forums/index.ph...ic=722399&st=0
i waited a few months this summer for more info on them and ended up going with something else due to the wait. felt like they were just some made up stuff since it was always the same response of "we have some coming"
buddyclub N+,....
yes i am happy because i saved a good amount and there were plenty of reviews on the buddyclubs to ease my decision making.
if you are not tracking i doubt anyone will tell a big enough difference to justify the $ difference between a cheaper brand and a higher end
Originally Posted by 3r1k,Dec 8 2010, 03:58 AM
Don't bother with Buddyclub N+.
Personal experience.
otherwise its just a useless statement to all of us.
