broken wheel stud (rear)
I'm not sure how, but I had 2 studs snap on me 2 days ago.
so far we've removed everything down - brake rotor etc - but we can't get the new stud in, it's too big
can anyone help me with what else, and how, I have to remove?
I've googled this, and I found old threads with "blocked" pics
looks like all that's left is axle nut? is that it?
does the bearing HAVE to be replaced?
thanks guys
thanks guys
can you guys show a pic how much you ground down the new stud? we already notched the shit out of the Shield
thanks so much!
this is ap1 if it makes any difference, and we don't have air tools, tried to remove axel nut, but there's no way ...
thanks so much!
nvmd, my dad worked them in, I assembled the rest, took the car for a test drive and re tightened the lug nuts, seems OK
can anyone recommend a set of good lug nuts and place to get them from?
Thanks guys
Thanks guys
Do you have OEM or aftermarket wheels? Or better yet what kind of lug seat do you require for your rims?
If aftermarket go with the evs evasive open ended steel lugs excellent quality, hold up well to impacting and they are a good value
Sent from my iPhone using Tapatalk
