Brake upgrade effects on bias
#111
Has anyone ran the Paragon rear 2pc rotors? No caliper bracket trimming / machining needed, nor any need to preshave the pads down. They are a solid disc, but with an aluminum hat.
http://paragonbrakes.com/2-piece-rot...r-honda-s2000/
#112
https://www.s2ki.com/forums/automoti...1185948/page4/
#113
Similar.weight savings compared to Urge, but no improvement in cooling. Perhaps some slight benefit from top hat not conducting as much heat as stock into hub.
But for a little more $, and the inconvenience of dealing with shaved pads, you could get massive improvement in rotor cooling.
Bottom line, most of the cost, hardly any of the benefits, compared to Urge.
#114
Hi, quick question. stock is floating caliper, but other BBK is fix caliper, which means those BBK has double piston area for each side. Why does you only calculate the on side of it.
#116
Oh, thanks, but for the effective radius on brake torque, he is half the height of the brake pad, which is controversial from what I learned. My understanding is that effective radius = rotation diameter/2 - Brake pad height.
#117
He uses the same process to measure effect brake force of stock components that he applies to aftermarket.
#118
Great topic and spreadsheet!
However, what about the effects of the fluid volume required for each caliper? Was this taken into account anywhere? Is this a non issue on S2K because of the diagonal split in the master?
#119
If you meant how do we make sure the total swept volume that mc can supply is sufficient for all these extra caliper pistons, that isn't a thing.
While there aremore pistons, they're smaller. Unless you're using calipers that throw bias way off scale, fluid volume is in same ballpark as stock.
If you're calipers need more volume than mc can supply, your bias would be so far off car wouldn't be drivable
