Brake Cylinder and Booster Install
Need Advice on Brake Master Cylinder and Vacuum Booster Replacement.
I am DIY-er when It comes to working on my DD S.
I need to replace the brake master cylinder and vacuum booster.
I have scoured YouTube and the Net for good tutorials, but have found little that is specific to the
S. I did come across these 2 vids on YouTube (not specific to the S) and wanted the groups input on whether I could
use them as a guide to do my DIY. If you can think anything not mentioned in the vids that is
specific to the S I would really appreciate your input.
For example, the following:
* Torque specs for the vacuum booster.
* Best practice for bench bleed of master cylinder
* Brand, where purchased for master cylinder bleed adapter kit
* Anything else etc.Bench Bleed of Master Cylinder
Master Cylinder and Booster Replacement
Thanks in advance S2Ki group!!!!!
xBoostx (05-16-2023)
regarding this particular replacement. Thanks for the link though.
Have you been able to complete this?
I am doing the same job and just posted up a question that maybe you know if you did the job. The manual goes through pretty in depth and I'm wondering how much of it is necessary.
https://www.s2ki.com/forums/s2000-un...rance-1218603/
auric
06-02-2019 10:32 AM
