Bilstein Pss9
Bilstein Pss9
Hey guys my car is on PSS9's without helper springs, Im lowered but it looks like the rear of the car is about a finger 1/2 higher than the front. I counted the threads all around and they are all the same. Is there another way I could measure it so I know that im getting equal ride height all around? The front spring is shorter than the rear spring I believe, so if I adjust the front to match the rear will that be okay? Any information would be appreciated.
You're probably going to need to do some adjusting and measuring, if even ride heights are your goal. The corner weights are different for each corner of the car, the front/rear spring rates are different for the PSS9s and the motion ratios are slightly different for the front and rear of the car. So...thread counting won't get you to an even ride height.
Take measurements as it currently sits and start from there. Use the distance from the fender lip to hub center. It's a little more accurate than "finger gaps". Remember to roll the car around a bit after you set it on the ground to let things settle before taking new measurements.
I just installed my pss9 yesterday without helper springs and the coilovers are all the way down but the ride height looks stock still can anybody help me? i have stock top hats. Do i need another one so it can be lower? i want at least another inch drop.
take some pics, without the helper springs you shouldnt have any gaps in the front and maybe just maybe like a quarter to half finger gap in the rear? Ive got the helper springs and both perches on mine and it sits pretty low. Also take a measurement from the centercap/axle nut to the top of the fender in inches and report back.
snitm
04-08-2018 08:07 AM
Apex1.0
10-06-2015 03:42 PM
