Another alignment question/advice
Hey guys just picked up my 2003 AP1 3months ago and installed coilovers and a whiteline front sway bar yesterday.
Got the shop to do me an alignment after the install and these are the results:
Front
Left -- Right
+0.06° -- +0.06° Toe
-1.54° -- -1.34° Camber
+8.26° -- +7.93° Caster
Rear
Left -- Right
-0.17° -- -0.16° Toe
-2.47° -- -2.51° Camber
I was wondering if these specs are good for street/track, should i do any changes to this? Any help/advice is appreciated! Thanks
Front
Left -- Right
Rear
Left -- Right
Received 1,376 Likes
8 degrees of caster. Cot dang.
I'm guessing this car is pretty low...but the alignment guy put the front camber as far positive as possible?
Track settings depend on your driving style and other mods and your setup overall. Most people like *around* -3 degrees all around...give or take a few decimals. But...that usually gets dialed in after driving it.
Your car should probably understeer. So it'd be good to learn on.
Depends on the tires. The lower the grip the less camber you need. But yeah that's a whole load of caster, you're on the verge of having a steering shimmy. But if it's not wandering or anything like that over bumps you're ok. The settings aren't perfectly symmetrical, just personal preference but it shouldn't affect anything. Not bad, expect decent tire life, rears probably last around 22,000km
I like that your alignment guy put a little toe in at the front. I too put a little toe in at the front, helps mid-corner grip, which is in my opinion the only place this car lacks, and also adds a little bit of stability under braking.
So you recommend around -3degree camber all around?
Sorry im new to all this!
Nah I say leave it you're on the cusp, but if the steering isn't wandering over bumps shouldn't be a problem. Also your tires aren't sticky enough to warrant more than -2 degrees up front.
But...since you've modded it, just try using your current setup as a baseline. Alignment angles depend on so many factors that it is much more effective to just drive the car first.
Which coilovers did you go with?
Did you really get toe out in the rear?
I've seen some alignment shops interpret a negative reading as toe in as well so that why I'm asking.
Unless you like snap oversteer I would make sure to dial in some toe in instead.
^good eye.
Positive is always in, as far as I've seen. I missed that it said negative. I thought those were just dashes.
Negative rear toe (toe out) is an awful idea.
Have you tried it?
