Sponsored by: Sake Bomb
aftermarket rotors and pads .. brake help !
Old 06-07-2011, 10:14 AM
S2KCHRIS305's Avatar
Default aftermarket rotors and pads .. brake help !
whats up guys im looking for some good aftermarket rotors n brake pads . i want them to work a bit better than the stock setup n i dont mind if they r drilled or slotted either one is alright for me . also i want the rotor to be oem size , no big brake kits . only brand ive heard of are stop tech but i want some opinions on them and would like more suggested brands u guys may know of .
Old 06-07-2011, 10:21 AM
Vinsfeld's Avatar
Have you tried a search?
Old 06-07-2011, 10:22 AM
yes ive tried search n it doesnt help at all i cant find anything . ever since they updated the sight the search is almost pointless .
Old 06-07-2011, 10:29 AM
Boofster's Avatar
Rotors from Science of Speed.
Pads from OEM AP1 Honda.
</end>
Old 06-07-2011, 10:33 AM
</end>
are the rotors oem size ? and does it bolt right up ?
Old 06-07-2011, 01:51 PM
WindingRoad's Avatar
PowerSlot rotors is a good way to go for Slotted OE fitment rotors. StopTech also makes drilled and drilled/slotted rotors.
Old 06-07-2011, 05:36 PM
wisdom's Avatar
</end>
Well...its a no brainer. It has to bolt up!
You can also try generic rotors with OEM pads. It's not that hard to decide what YOU want to do. You give US no info whether your car is track duty or daily duty or both?
Old 06-07-2011, 09:00 PM
MeganFoxAP1's Avatar
Just buy some cheap ass Centric Rotors and run some Ferodo DS2500 or Carbotech AX6 if it's just a street car.
Plenty of braking power there for the street.
Old 06-07-2011, 09:28 PM
S2Keri's Avatar
PowerSlot and StopTech have merged from what I was told. I recently got the PowerSlot with Akebono pads, always been my favorite pads due to the nice bite and zero brake dust they have. Try them out I'm sure you'll like them
Old 06-09-2011, 08:22 AM
can u resurface these aftermarket rotors ? and how long do they usually last ? if i cant resurface the after market pads i might just get new oem rotors with ap1 pads
Quick Reply: aftermarket rotors and pads .. brake help !
