Affordable Front Sway Bar Stiffness
I've done some searching but can't find any definitive rates. I found a lot of xx% stiffer but stiffer compared to what year S2000 bar (they change every 2-3 model years)?
I'd like the stiffness rate or at least which bar is the stiffest from the following:
Eibach
Whiteline
Cusco adj and non-adj
Or any other affordable bar. Thanks.
Eibach
Whiteline
(Copy and pasted from another post)
S2000 Eibach Sway Bar rates:
Front: 32mm Adjustable (HOLLOW)
Pos.1 - 65 N/mm (368lbs/in)
Pos.2 - 73 N/mm (416lbs/in)
Weight - 4.8kg (10.6lbs.)
Rear: 29mm Adjustable (HOLLOW)
Pos.1 - 90 N/mm (515lbs/in)
Pos.2 - 106 N/mm (605lbs/in)
Weight - 4.9kg (10.8lbs.)
I was able to search the forums for OEM sway bar specs for comparison:
OEM S2000 Sway Bar Information:
AP1 100 series-
Front sway bar part number: 51300-S2A-003
28.2mm (HOLLOW) with a 5mm Sidewall
Rating at 61.6N/mm
Rear sway bar part number: 52300-S2A-013
27.2mm (HOLLOW) with a 5.3mm Sidewall
Rating at 73N/mm
AP1 110 Series-
51300-S2A-J01
27.2mm (HOLLOW) with a 5mm Sidewall
Rating at 53.6N/mm
Rating at 73N/mm
AP2 120 Series-
Front sway bar part number: 51300-S2A-013
26.5mm (HOLLOW) with a 4.5mm Sidewall
Rating at 46.6N/mm
Rear sway bar part number: 52300-S2A-J01
27.2mm (HOLLOW) with a 4.5mm Sidewall
Rating at 67.6N/mm
130 Series-
Rating at 46.6N/mm
Rear Sway bar part number:
Do not have
25.2mm (HOLLOW) with a 4.5mm Sidewall
Rating at 51.6N/mm
AP1 100 series-
Rating at 61.6N/mm
Rating at 73N/mm
AP1 110 Series-
51300-S2A-J01
Rating at 53.6N/mm
Rating at 73N/mm
AP2 120 Series-
Rating at 46.6N/mm
Rating at 67.6N/mm
130 Series-
Rating at 46.6N/mm
Do not have
Rating at 51.6N/mm
Thanks yeah I believe I've seen that. I have a 2000my and if I get an eibach bar it would only be as stiff as my oem rear bar. I'm looking for something a lot stiffer but affordable. Anyone got specs on the other cusco or whiteline?
Yeah I know what the Saner rates are but its not even available anymore and its not exactly affordable.
Oh, I'm probably going to go with the whiteline bar.
