Abs-vsa light on
Abs-vsa light on
Ok so I've been searching and searching and read a lot of different answers so I'm gonna ask here. I installed my function and form type 2 coils today and when I went to drive my abs light, vsa and ! Light are on and I know I didn't break any sensors, but, I lowered the car a lot, and now I need an alignment, I read that if the alignment is off/steering is off, then it'll throw those codes, so so y'all think an alignment will solve my problem? No precious problem with abs or vsa before so I think it's due to the alignment, but just wondering
Well for anyone who cares, I pulled the abs code, code 13- which is front left sensor if I'm correct, I've pulled the wheel off and the sensor is done, even cleaned the sensor, idk why it's saying its bad, I mean all I did was put coilovers on how in the world does that have anything to do with my abs sensor? I'd love if others would chime in
Might just have to replace the sensor...
I'm curious as to what you ended up doing since I have the same problem on mine...and I replaced the brake pads and rotors and when I started the car up, the lights came on.
Also, what did you use to read the code? A regular code reader doesn't seem to read the code
