S2000 Body and Paint Body kits, paint, ding repair and related discussions
Screws through the floor pan
Old 01-23-2016 | 11:00 PM
dane795's Avatar
Default Screws through the floor pan
This weekend I've been redoing the sound system how I'd like and detailing the interior, it turns out the old amp was mounted with self tapping screws by the previous owner-I can feel them underneath the car. I took the screws out but how do I plug the holes while preventing rust? My first thought is to fill them with silicone but then if water gets underneath that I'm in trouble. The car is a daily driver all seasons and I plan on having it for a very long time so I'd like to do it right.
Old 01-24-2016 | 04:36 PM
Vanishing Point's Avatar
First I would remove any existing rust within those holes, then apply paint both inside and outside the holes. A spray on undercoat applied to underside and inside should permanently seal the area. This is the cheaper method, otherwise you are looking at welding the holes, grinding the area smooth and repainting/sealing the area.
Old 01-26-2016 | 08:25 PM
dane795's Avatar
Sounds like a good plan. I think I'll take it to a body shop just to get an estimate but I'll likely go the other route. Thanks! And do you have any recommendations for a spray on undercoat?
Old 01-27-2016 | 07:22 AM
The body shop might offer a similar product to what I've listed, the prep work (cleaning dirt, oil, etc from area to be sealed is the key) and applying paint prior to sealing is the other key. This site has a whole myriad of products for prep, rust eliminator/surface prep and sealing. The other brand i would trust for this job is the 3M sealant.
http://www.eastwood.com/ew-textured-...html?reltype=3
Old 01-27-2016 | 01:37 PM
hybridz0r's Avatar
You could pop-rivet the hole and under coat over it.
Old 01-29-2016 | 08:40 AM
mongomery1234's Avatar
Nothing some bondo cant fix.
ayau
08-03-2010 05:35 PM
sound_wave
02-19-2010 01:42 PM
s2000ky
02-24-2008 12:42 PM
jert534
08-14-2006 12:31 PM
march2000
04-26-2006 02:45 PM
