Rear quarter repair, remove the top?
Hey all, looking for some advice. I'm rebuilding my AP2 after some rear end/quarter damage and currently at a decision point. My current passenger rear quarter is fairly mangled. I've got a frame guy that'll be helping me out w/ the frame/structure, and he's mentioned he may be able to pull out most of the rear quarter damage functionally, and then I'd tackle the bodywork finishing some other time.
On the flip side, I've found a local shell being parted out w/ a rear quarter that's in decent shape, for a decent price. From my understanding, the best way to leverage that is drill out the quarter's spot welds on each and swap over. This would minimize or maybe eliminate the need for future bodywork (filler) and likely produce the best finish. The pickle though seems to be the rear tray molding (below) covering some spot welds, which looks like it may require removing the soft top. I absolutely do not want to screw up the top and its fitment; full removal looks like a bear, and I already have a bad experience with my Miata's top adjustment and leaking (which is a simpler design).
So in the end, I'm trying to determine if it's worth the hassle and risk of additional teardown for the new rear quarter (if indeed req'd) vs. settling for whatever my frame guy can bend back. The car will be a dedicated track car going forward and not looking to return it to OEM quality, but it would obviously be nice if it didn't look like total poo-poo w/ mangled metal. A secondary factor is that I also bought a Ballade roll bar which I'll be installing, which from what I understand requires lots of interior removal but not necessarily the top.
What are your thoughts?
as someone who's messed up a soft top before, I'd be cautious about removing it. Have you considered asking your frame guy if he thinks the repair will be good enough for track use? That might help you decide if it's worth the risk of swapping the quarter panel.
Yep, to replace the quarter the top mostly has to come out. Removing and putting it back in is no issue really though. Mine has been removed and replace for a quarter panel replacement as well. Only thing is to pay attention to where the limiting straps bolt in. Mine were put back in the wrong spots. Fixable but kind of a pain after the fact.
Thanks for the advice, everyone
Limiting straps like the modifry elastics?
I appreciate the thought
Thank you! That's a golden nugget.
YES, pull it out. It's not that bad but then again I am experienced doing this. You should be able to remove the top & frame as one with a few more bolts removed and not have to mess with detaching and re-attaching the top. You can probably separate the soft top from the car to give you access to the molding bolts. Wish I was traveling to CT sometime soon so I could just quickly do it for you!
I'm in the same situation as you and found this video useful.
S2000 Surgery - Fixing CUT Quarter Panels on the S10K
Pinky (08-28-2024)
That Miata Guy
08-03-2020 12:11 PM
Stoatmaster
06-26-2013 09:31 AM
