OEM Weatherstriping for Baysonr Lip
Just got the baysonr lip from ebay. I assume i will need some weatherstripping for installing this lip? Were should i purchase some black stripping at? Does this act as double sided tape? Is this all i will need to install?
Hardtopguy.com
It's just weather stripping... Protects the lip from scratching the bumper. You can get 3G double sided tape to hold it up instead. If it sags too low bolted up then use the 3m tape.
Sent from my iPhone using Tapatalk
got ya, yea i didnt know if the weatherstripping was tape as well. I guess ill just grab some tape then as it will be used as a protective layer same as the weatherstripping i assume. My tsx kit has this as well as my infiniti lip.
I have the BaysonR lip and the hardware provided lined up perfectly with the OEM bumper bolts...why would you just use 3M? I used the OEM weatherstripping to prevent the lip from scratching the bumper, but other than that everything that came with my ebay lip was all you should need.
It is a tape. You peel off the cover and just stick it on.
