How to remove Driver's side Mirror
If its just the mirror then grab and pull with both hands gently.
If its the whole piece attached to the car then you have to remove the speaker and put your arm up inside to undo the bolts.
if the entire mirror is loose where in connects to the door then take off the entire door panel. Move the plastic shield out of your way and look up to find the 3(i think) bolts holding it on. Tighten them up, be sure not to over tighten or the internal nuts and break loose and then your really screwed!
seung
10-23-2013 04:27 PM
