S2000 Body and Paint Body kits, paint, ding repair and related discussions
Help Removing This Trim Piece
Old 03-20-2010, 01:45 PM
Whoabitchin's Avatar
Do I remove the seat and climb in underneath there to unbolt the soft top and then this trim piece. Can I get to it from inside the trunk?
Old 03-20-2010, 04:49 PM
R1_Pilot's Avatar
You cant get it from the trunk. You need to remove the plastic shelf behind the seats, the two side plastics and possibly a few more. You will see the rain gutter and will need to loosen it (I believe its a bunch of 10mm nuts) That rain gutter is riveted to the soft top. Then behind that you will find the nuts holding the trim.
I hate to say this, but its pita to do that.
J
Old 03-20-2010, 05:23 PM
Thanks. It will be a pain but guess it has to be done for a proper paint job.
Old 03-20-2010, 07:07 PM
305s2k's Avatar
I was going to remove this piece now that I am doing my repaint, but it is such a PITA that Im just going to tape it up carefully. I dont plan on taking off my top anyways.
Old 03-21-2010, 09:42 AM
freshs2k's Avatar
It is a pita to take that off but if you use some fine line tape and scuff all the way up to that edge and properly clean any water or dust from that area you shouldn't have a problem with seeing any hard lines or the paint peeling back. I did it with my first paint job on my s2000 without issues. I then got a hard top and removed my entire soft top frame for my third paint job it was a pain.
Old 03-22-2010, 10:57 PM
Texas Made's Avatar
alot of work ..but the reward .got to do it
Old 03-23-2010, 12:52 PM
I got it off, took me 4 hours but its off. I think I couldve pulled the engine out faster haha.
liquidgsr
06-06-2012 01:36 PM
Ebi17
03-24-2012 02:17 AM
Euroflavor
07-12-2011 07:00 PM
Ellington
05-10-2010 06:25 PM
s2kc's
04-06-2010 04:54 PM
Quick Reply: Help Removing This Trim Piece
