ebay oem rear spoiler
#331
It was shipped Fedex. Just a FYI an indirect signature is required in case you won't be home when it is out for delivery.
#332
hi,
another question: how thick was your tape? my tape has 1,5mm.
i ask myself if that is to much and if the spoiler will sit to high
with space between spoiler and trunk.
i would appreciate a fast answer, thanks
#333
There's no gap between the spoiler and trunk. There's a lip that goes around the bottom of the spoiler so as long as you put the tape on the inside of it it'll fill in that space. I believe that'll help with the water question that was posed earlier also.
#334
the reason for my question is:
the spoiler came with 3m tape which is 1,1mm thick.
because i`'m very careful, i have ordered a 3m pt1500
at a german online shop. This tape is 1,5mm thick.
when I have sticked the tape on the spoiler, it will be too late.
thats why im asking if 1,5mm is ok or too thick and how thick your tape was
#337
There is enough tape to put along the entire perimeter of the lip, just inside the edge as mentioned. With proper prep and cleaning of the trunk surface, it will be a very strong bond. You would have a hard time ripping it off even if you wanted to. Make sure you get it lined up right the first time, because it's not going to move.
If you think the supplied tape is not sufficient, then you need to drill the holes in your trunk and bolt it down.
#338
