Dent in fender on corner of wheel well
Hey guys. Just want to get some opinions on what I should do with this dent i picked up autocrossing. As you should be able to see in the image, i dented my front driver side fender right at the corner of the bottom of the wheel well where the fender meets with the fender. Could I get some opinions on whether this is easily repairable or not? It seems complex in shape so I am a little worried about it. Could anyone give an estimate on how much a shop would charge to fix it?
In case the picture didnt work, here is the link to it:
http://imgur.com/bqrpX1n
Pretty sure that needs autobody repair work, it looks too deep for dentless removal.
For sure, they will bend it out as much as possible, and likely add some filler to smooth it over, but yeah body shops can pretty much do it all.
Originally Posted by s2kaok' timestamp='1451658997' post='23841226
[quote name='zeroptzero' timestamp='1451655176' post='23841212']
[/quote]
How much do you think a shop will charge to fix it and repaint it?
Originally Posted by zeroptzero' timestamp='1451694722' post='23841527
[quote name='s2kaok' timestamp='1451658997' post='23841226']
[/quote]
[/quote]
No idea as my region is different than yours. It depends on who you use - small guy vs. big repair shop - how picky you are about the finished product and how much blending they will do to the fender to make the paint match. A small spot repair maybe $300, a larger repair with blending into the entire fender maybe $500-$600 ? Lots of variation. Look around for a small guy who has less overhead expenses and can maybe do the work for cash.
Thank you for everybody's input. I am glad the consensus is that it's repairable. What about protecting the metal from rusting until i do fix it? I want to find a way to seal it completely from moisture. I thought a thick coat of plastidip will do the job (keep in mind this is just temporary, just a way to protect the area from rusting) but I am not so sure.
HJZ
01-12-2004 03:25 AM
