Changing the top window seals. (how hard is it?)
I discovered quite a bit of water streams down the windows of both my windows the first rainy day since I bought my AP1.
As others suggested, I went ahead and bought the Honda Shin-Etsu tube and applied both on sides. The passenger side (which was the worst side) was fixed 100%. Even during heavy rain at 80mph, it held up no problem.
But the driver side still continues to release a stream of water down the window just before the curve. I try pushing the seal out from inside and then put the window up. Helps for a bit until I reach 30+ mph and water slips between the seal and window.
I'll try applying the grease one more time but I think the driver side seal is just warped into that shape or at least just on that one spot.
I've found some used/new S2000 weather seals on eBay but was wondering how hard is it to install these. Also on the eBay description, seller says it's uncut. Do they have a mark where I'm suppose to cut these so my top can go down correctly, or are these just for the hardtop only.
http://www.ebay.com/itm/00-03-HONDA-...397900&vxp=mtr
russellhq
10-16-2007 11:19 AM
s2000 gib
12-07-2005 11:12 AM
