Rocky Mountain S2000 Owners Rocky Mountain Owners Club including Colorado
Rear Tires again... (Local opinions - please help)
Old 08-18-2003, 01:59 PM
Red-S2k-00's Avatar
Default Rear Tires again... (Local opinions - please help)
I need some help. I have the stock rims on my car (Year 2000) and the rear S-02's are gone. I really don
Old 08-18-2003, 07:25 PM
Kwando's Avatar
If you go with something other than OEM S02's i would say go with the 245. If you compare the OEM 225/50 with a 245/45 they are almost identical in width.
I know that Milo use to run a wider width on his OEM rims.
Best bet would be to stay with the OEM S02's.
Old 08-20-2003, 01:09 AM
Milo's Avatar
Yeah, I ran a 225/50 on the front and 245 on the rear with all season tires. That's why I went with wider tires. I felt that the added width made up for lesser performance a little. Also, my friend with an S2k went with some BF Goodrich TA KDW G-force tires.*edit: The size he went with was 245/45 16* They chirp and squeal a bit more than the S02's but I think they give a little more progressive break away. They may not stick as well as the S02's but they're easier to drive hard with IMHO.
Old 08-20-2003, 11:36 AM
Red-S2k-00's Avatar
Thanks Kwando and Milo. My wife and I are expecting our 3rd child very soon, so money is a bit tight right now. It's tough to spend the money on S02's when I can get a good tire from Yoko for a lot less.
Old 08-20-2003, 05:22 PM
pfb
pfb's Avatar
I run 245's on the rear for my race tires... but 225's up front!
Unless you are replacing all four, I'd just bite the bullet and go with the OEM S02's
Old 08-21-2003, 02:55 PM
vicbrasil's Avatar
I went with the Yokohamas when I wore out the rears and they were horrendous! As I drove between Lincoln and Castle Rock, I had trouble keeping the back end under control. The grooves in the road caused the car to shimmy. After 500 miles, dropping the tire pressure to 30 PSI I went back to my dealer and told them that I needed something else. They agreed to replace the rears with the SO2 and no more problems. The steel belts on the side walls caused the problem. I had to pay the difference but the ride is worth it.
Old 08-24-2003, 07:08 PM
Red-S2k-00's Avatar
Thanks Vic. I think I'll bite the bullet and just put the OEM's back on. I like the way they look and handle. Maybe when it is time to replace the rears again, the fronts will have to be replaced as well. At that time I may look at a different brand.
Old 08-24-2003, 07:09 PM
Red-S2k-00's Avatar
P.S. the new baby doesn't have to eat......Right? ;-)
Old 08-24-2003, 07:18 PM
vicbrasil's Avatar
My thoughts exactly!~
Old 08-25-2003, 08:25 PM
Kwando's Avatar
LOL you guys are crazy!
Quick Reply: Rear Tires again... (Local opinions - please help)
