Vortech S/C install - a running documentary.
The coolant pump and charge-cooler rad just went in:
All brass fitting threads were "siliconed" in for insurance against leaks. Tested the motor, works fine, left the two hoses in the engine bay capped for now.
Coolant reservoir tank also installed:
Bumper was quite easy to remove except for the last part where you're supposed to PULL LIKE CRAZY on each side to dislodge the 3 clips. Not knowing how the clips worked, I was a bit cautious. Once it's off, you can see that they are just little "bumps" of plastic that slot into their matching gaps in the bumper cap. Slipping a thin screw driver into each bump helps them to come free.
Next up:
Putting together the jigsaw puzzle that is the S/C & its holding bracket.
Next up:
Sideways, have a look here:
http://www.vortechsuperchargers.com/pdf/ma...ls/4hs218im.pdf
Page 24 has a nice picture of what the brackets look like.
