Prairie Redliners Canadian Prairie Provinces. Alberta, Saskatchewan, Manitoba
Sat May 2nd - Brake kit install day
Old 05-01-2009 | 07:10 AM
coldrsx's Avatar
Default Sat May 2nd - Brake kit install day
Tomorrow i will be putting on my stoptech stage 2 kit most of the day. I am looking forward to some slotted rotors and more importantly SS lines. They will be kept paired to my Spoon mono blocs up front.
If anyone wants to drop by (parent's house garage in the SW) pm me.
i know you want to be my pedal pusher for bleeding!
pics to follow
Old 05-01-2009 | 07:37 AM
trunger's Avatar
what time, you doing it? early in the morning? or evening?
Old 05-01-2009 | 07:50 AM
coldrsx's Avatar
going to try to get a reasonably early start... maybe 11ish
Old 05-01-2009 | 08:07 AM
trunger's Avatar
ah damn, i would come, but i work til 6
Old 05-01-2009 | 08:14 AM
coldrsx's Avatar
no worries... maybe call me when done work as i very much could be frustrated/drunk by then
Old 05-01-2009 | 10:31 AM
Dampachi06's Avatar
if you need a hand let me know
Old 05-01-2009 | 11:22 AM
saaboteur's Avatar
Dude, it's not too difficult, just be sure you a) have some of the special flare nut wrenches to get at the brake lines and b) your ma or pa to do the pedal pumping!
And maybe some drill bits and screw extractors in case the rotor retaining bolts are tough to get out.
Another way to bleed without pedal pumping is to use a coolant system pressure tester, with an adaptor that can screw onto brake or clutch reservoir. Trick is to find the right adaptor. I do this all the time on my Saabs, but fortuitously, the coolant tank cap is the same thread pitch as the brake/clutch reservoir. I could bleed the brakes or the clutch in like 10 minutes.
Old 05-01-2009 | 12:12 PM
coldrsx's Avatar
oh i have done rotors/lines prob a half dozen times.... but more just that extra people to drink beer with is fun
Old 05-02-2009 | 03:27 PM
trunger's Avatar
still working on it?
Old 05-02-2009 | 10:11 PM
Turbos2kedm's Avatar
Would of loved to come out but having probs of my own damn turbo !
Quick Reply: Sat May 2nd - Brake kit install day
