Prairie Redliners Canadian Prairie Provinces. Alberta, Saskatchewan, Manitoba
Can coil over systems survive our winters?
Old 03-07-2006 | 03:39 PM
FormerH22a4's Avatar
Default Can coil over systems survive our winters?
I drive my car all year and in all conditions.
This summer, I am considering lowering it by 1" or so and am wondering if going with a coilover would be better than doing a straight drop.
I want to be able to raise the car for winter.
has anyone on here run a coil-over system all seasons without having it seize up due to salt and corrosion?
Old 03-07-2006 | 05:19 PM
Woodson's Avatar
I'd like to know this too.
Old 03-07-2006 | 08:10 PM
4doorj's Avatar
i have had coil overs in my other two other cars... and they work fine!!!! just got to spray the dirt off before lowering it or raising it
Old 03-08-2006 | 04:04 PM
Fongu's Avatar
I've got the KW Variant 3 coilovers that GoFast sell on the site. Although I don't drive the car in winter, this is the first time I've seen one of selling points was the "salt spray test". The coilovers are stainless steel so at least this brand would be OK. Here's the ad.
http://www.kw-suspension.com/en/20_Technol..._Test/index.php
Oh yeah they are a pretty good street/track coilover too.
Old 03-08-2006 | 04:20 PM
Woodson's Avatar
Would you need an alignment every time you raise or lower the car?
Old 03-08-2006 | 05:50 PM
koala's Avatar
Technically yes, but in theory all you should throw out is the camber... and a little extra negative camber when its a bit lower is probably not a huge deal unless you're concerned about excessive tire wear.
Old 03-09-2006 | 03:35 PM
Fongu's Avatar
I don't know about you, but it bugs me when the alignment is slightly off. The height change also changes the toe. The rear toe actually changes quite a bit for older stock suspensions.
Old 03-09-2006 | 04:05 PM
koala's Avatar
Ah, good point.
Old 03-09-2006 | 04:31 PM
Woodson's Avatar
I don't mind getting an alignment every spring and fall as long as this does not wear anything out.
Old 03-09-2006 | 07:12 PM
nish's Avatar
There was a discussion about this on a local Winnipeg board, but I can't find it. From what I remember, you just have to be religious about spraying inside your wheel wells regularly in the winter. The cleaner you keep them, the easier they will be to adjust in the spring.
johnsy_20
10-07-2008 05:27 PM
axis_of_evil
15
11-26-2006 04:38 PM
Jakup
09-25-2006 05:13 AM
FormerH22a4
03-25-2006 11:37 AM
StknCaS2k
07-08-2003 11:19 PM
Quick Reply: Can coil over systems survive our winters?
