Berk HFC
Berk HFC
Hi all, I was wondering if anyone has ever installed a Berk HFC (63.5mm) onto the stock ap1 manifold. The reason I'm asking is because my mechanic installed mine last week and it seems to leak from that connection (fumes in the cabin). He used the stock donut gasket with the stock spring loaded bolts. He said that the stock gasket was not the best fit. I was wondering if anyone used an alternative type of gasket or had any suggestions for this fitment issue(I don't know if it matters but I am running a Toda cat back exhaust).
Thanks in advance
Thanks in advance
I think a new gasket may work since it is somewhat of a crush type gasket where the seal is made. Are you sure its not just the stronger smell of a HFC? cuz they do smell a bit stronger than the oem cat just by design.
rodneyyar
05-25-2018 05:51 PM
