adjusting time on '02 OEM head unit
I didn't get much luck in my request for help so I figure
to try the PR folks and seek help
Here goes:
Can someone pls. advise on how I can adjust time on a 2002 OEM head unit.
I bought this from someone local (SF Bay) but I have no clue how to
adjust the time. Right now it's just flashing.
I have a MY2000 and I replaced my head unit with 2002 OEM unit
so my owner's manual is not a good source.
Thanks for your help.
Bob/Rob
So far this is the most relevant response but with no luck and perhaps
if someone can validate (I surely can't get it to work)
>just hold down the AM/FM button til the time number flashes...
>once its flashing....
>click the #4 preset button to adjust the Hours...
>click the #5 preset button to adjust the Minutes...
>once you have it set to the desired time, click the AM/FM button again and you >should be done...
>there is no PM/AM time so itll just read... example: 9.43 and youll just have to >know if its am or pm, considering if its darkout or not
Here goes:
Bob/Rob
From my manual: "To set the hours, press the H (Preset 4) button while pressing the CLOCK (SCAN/RPT) button. Press and hold the H button until the hour advances to the desired time. To set the minutes, press the M (Preset 5) button while pressing the CLOCK (SCAN/RPT) button. Press and hold the M button until the minutes numbers advance to the desired time."
BobbyS2k
10-16-2005 07:24 PM
