Tuner options for AP1
Originally Posted by urBan_dK' timestamp='1423804011' post='23504418
[quote name='s2000Junky' timestamp='1423370376' post='23497763']pick up 8-10tq and 15whp from 4500-5900k rpm.
[/quote]
Better go fix in your original post and the first quote too
Originally Posted by s2000Junky' timestamp='1423872140' post='23505413
[quote name='urBan_dK' timestamp='1423804011' post='23504418']
[/quote]
[/quote]
I thought about it, but then said nah.... No one else is as nitpicky about this shit as you are
If I had read about the neo/vafc +pressure regulator approach before my upgrades, I might have gone that route, but I'm glad I didn't.
I did the Haltech and a gernby mid pipe - this may be the most costly route discussed here, but I wanted to set myself up for many more mods in the future - potentially FI as well.
Also, coming from a vintage car, I was accustomed to tuning and didn't want to give that up, even though I'm no pro, or mechanic.
The bottom line, however you do it, lowering the vtech and improving the mid range exhaust flow, tq, and hp absolutely transforms the car - it is so fantastic to feel and hear it just pull smooth and quick - no flat spot, no drone, no buzz, just quick rips up and down the tach - exactly as you would expect it to be!
I did get it to pass emissions with a tail pipe sniffer, but I had to work hard to get the cat up to temp!
Its a simple fuel and vtec piggy back controller that has a user interface so no computer needed. The downside is it cant add fuel on our car, only subtract it, which is 2/3rds of whats needed anyway, and the other 1/3rd in the mid range from the new lowered vtec can be enriched mechanically with an adjustable bolt in fpr. Its simple and effective for a bolt on N/A option. You want the last iteration of the vafc line up though with is called the Neo, simply because of the improved vtec control. The older vafc/vafc2 only controlled vtec based on rpm rather then rpm and throttle position both for retaining oem type control/performance. The others work, but its a bit annoying and waste of fuel to be cruising in vtec at 3500-4k rpm, which inevitably ends up happening if you want to get the full benefit of lowering vtec to the rpm where it picks up power. Alternatively you can raise it around 5k, which isn't ideal either.
