NEED HELP WITH SRS LIGHT
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
i was taking out my entire softop frame and motors, and in da process you have to remove your roll hoops/ disconnect the seat belt wire.......
some how it triggered the srs system n now it wont go away. i hear there's a way to reset the srs light with a paper clip... could someone show me how? thanks
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-5yr.png)
here try this...i did this in my 2001 acura cl type s...hope this helps!
First make sure your key is out of the ignition.
Step 1: You need to prepare the standard paperclip so you can use it to reset the SRS light.
Step 2: Twist your paperclip to make it in to this shape, it will make your life a lot easier to plug in and out of the SRS clip.
Step 3: Remove the bottom panel under the dash, two twist clips which can be easily taken off. (turn counter-clockwise)
Step 4: After the bottom panel is exposed, locate the fuse box (see drawing for location)
Step 5: Locate the SRS plug above the fuses, you will see the yellow clip, this is your SRS clip. (only thing thats yellow in the fuse box)
Step 6: Unplug the clip. You should see two pin holes
Step 7: plug the paperclip in to the 2-pin clip.
Step 8: At this point, place the key in and click to the Ingition On position II
Step 9: You should hear beeps for 3 seconds, and when the beep is gone, the SRS should turn OFF.
Step 10: Take the paperclip out and the light should come back on (ignition remains the same).
Step 11: plug the paperclip back in to complete the curcuit again, the SRS light should Flash TWICE and turn OFF again.
Step 12: Remove the paperclip now and you shouldn't be able to see the SRS turn on.
Step 13 (Final Step) At this point, take keys out then remove the paperclip and put the 2-pin clip back in to the proper place. Secure the bottom dash back in to place. Test out the SRS again with the Ignition Position. It should beep then the SRS should turn off.
