440cc injectors
Originally Posted by blacknwhite,Oct 1 2008, 09:30 PM
why do you want 440? just get 1200cc!
And just fyi for you, the best approach in getting the best performance from your boost level and engine flow rate is to run the smallest injector you can get away with without over extending your injector duty cycle to run safe afr levels. Getting a size or two up in injector flow rate for anticipating upping boost in the near future is one thing, but if you know you are not going beyond a certain point then it isn't ideal for the best tune possible. Bigger injectors inherently idle shitty and don't have the same fine fuel delivery properties as a smaller type, matching fuel pressure is very important in this aspect of tuning with the right size injector, you run too big of an injector and you have to run to low of fuel pressure to compensate and then have problems with poor inconsistent fuel delivery. 1200cc?? sorry but im not going to be making 700whp to make those work ever.
Originally Posted by s2000Junky,Oct 2 2008, 12:48 AM
Thanks biatch don't you have some 440's Ray?
I'm a broke ass pu$$y with expensive habbits
All kidding aside, how are you planning to "tune" bigger injectors?
