Are there any local (PDX) shops which can do a clutch for less than $1.5k?
I need to get a clutch job done, but the two shops I've asked both said they have to pull the engine to do the clutch, so they tack on a lot of hours. Unsure of how legit this is, I'm wondering if there are any shops which can do a clutch job for less than $1,500?
Thanks guys!
Thanks guys!
Thanks guys!
Thanks guys!
pull the engine and for $1500. are they nuts? those two shops you've went dont know jack. Call Trackforged 1-503-674-0293 and talk to Dave or John. They'll hook you up with better price on clutch kit and install.
PULL THE MOTOR?
They're high. You have to seperate the trans from the motor to pull it. &*%^ that noise.
If Trackforged can't help you, call AR Auto Service in Lake Oswego. Eddie and co did my Comptech flywheel/ACT clutch install as well as my Ap2 valve retainer install in my first AP1 I owned. They're still my go-to shop, even though I live in Seattle these days.
http://forums.s2kca.com/showthread.php?t=14201
here is a link to the diy I used, it is very good. Uses the "engine tilt method". This will save you a lot of money.
It is more difficult than some other cars but not that big a deal... I have done three in my garage some time back. The procedure is to get the car high, lower the engine (it has bolts to accommodate the move), and tilt it a little to pull the transmission off.
It always took me about 12+ hours but I did them by myself with cheap home tools. I think the book is 8 hours so at $60 the labor charge would come to $480. I don't remember what parts are but guess about $900 so with a shop charge and tax $1500 is not out of line.
Just the price of having this car... parts and labor have always been higher than others.
