Need some goodies polished
Hey guys Just like the top says im getting in some parts for my S and I would like them polished.... Any shops or people that do good metal polishing? Its an intake manifold specifically
you would have to sand down all of the casting marks. dremmels tend to take chunks off the aluminum
sand paper grit: 400, 600, 800, 1200. then use a polishing compound like black magic. aprox 15-20 times until it takes a mirror finish.
if you spend 3-4 hours a day, you should have a very nice piece in about 2-3 weeks.
an intake manifold is going to be a little harder because of all of the tight spots wich are harder to reach..
you can also skip all of the sanding if you take it to a powdercoat place, they can sand blast it to a smooth finish and you can do the polishing. then it would only take about a week.
i was able to polish my whole bike frame in probably roughly about 20hours? + a couple hours to drop the motor. its def not something you will want to do in one sitting but its quite rewarding once you have the end result.
