Where to get an alignment in NE Ohio
My car is lowered on the PSS suspension system with about a finger gap all around, for the most part. I went to a recent meet and a couple of folks suggested Parrish Mcintyre in Medina, which is where I live. I called and talked to Joel - real nice guy. Took it out there today at noon and it won't go onto their rack b/c it's too low.
I really need to find a spot that has a recessed rack - one built into the floor. I tried Valley Mitsu thinking they might have one for the EVO's, but they don't. Does anyone else know of a place around Medina that has one? Motomotion is no longer doing them, so that's not an option, either. If I have to drive to one, that's fine, but I really don't want to be driving to Cbus, as an example, for an alignment.
By the way, here is what I am going with on the alignment. Let me know if you have suggestions. Car is driven on the street with an SCCA event once in a while. Always drive in fair weather, never in the rain. Looking for stability and decent tire wear.
~1 - 1.5deg front camber
0.1 deg total toe, or less
~2 - 2.5deg rear camber
0.2 - 0.3 deg total rear toe
MAX Caster up front - hopefully 6-6.5 degrees, or better.
Thanks,
Shumax
Thanks,
Shumax
Thanks, I will give them a call. Does anyone know of a shop that definitely does have a rack built into the ground? I Googled it and found "Xtreme Performance" in North Olmstead, but I know nothing about them. Any thoughts?
Thanks again,
Shumax
A 2
15
05-28-2013 12:41 PM
jlstyle82
10-05-2007 08:16 AM
hchu304
20
07-21-2003 11:54 PM
hi50
06-30-2002 04:51 PM
