Ohio S2000 Club Ohio S2000 Owners Club
Replacing Pads and Rotors
Old 05-01-2006, 05:42 AM
Mocky's Avatar
Default Replacing Pads and Rotors
Question..
Is pad/rotor replacement a Saturday afternoon job? I'm wondering because Cheryl went to the Honda dealer and was told that all four rotors are warped. Replacement parts and labor in Canada are ridiculously high so I was thinking I could pick up the parts from Jeff and install them down here. I just don't know how to.. Was hoping someone could help out one weekend.
Also, on a side note, are oem pads/rotors the best way to go? Aftermarket? Suggestions?
Thanks in advance
Old 05-01-2006, 07:39 AM
duff0000's Avatar
Yes, it can be done in a saturday afternoon.
Old 05-01-2006, 07:47 AM
ROGUE3308's Avatar
Stop Techs for $100 each.
Old 05-01-2006, 07:52 AM
LilJapnBoy's Avatar
Ah, now I know why Cheryl is dating you.....
You've never done this much manual car work before.....
Old 05-01-2006, 08:07 AM
Mocky's Avatar
i'll run it by the boss..... that's just rotors, right? run stoptech rotors, oem pads? stoptech make pads as well?
Old 05-01-2006, 08:29 AM
ROGUE3308's Avatar
not sure about the pads. rotors yes.
Old 05-01-2006, 09:06 AM
efthimios's Avatar
I just picked up some Brembos....you can get all 4 for around the same as Stoptechs or maybe even less
Old 05-01-2006, 09:08 AM
Mocky's Avatar
easy to install?
Old 05-01-2006, 09:15 AM
efthimios's Avatar
2 screws on each hold them on...you may need an impact to get them out.
Old 05-01-2006, 09:18 AM
Jaydem's Avatar
Mocky this is pretty easy to do.....
take a couple of bolts of holding the calipers/pads in place.....then remove the 2 screw holding the rotors to the hub....and then reverse everything....(get a couple cans of brake cleaner) to clean everything off.....
P.S support the caliper with some wire (ex. support for spring of something close) dont let caliper hang on brake line!
good luck....pm me with any questions!
Jay
Quick Reply: Replacing Pads and Rotors
