Popeye's test drive
Popeye's test drive
First off the hard facts on the crystal black pearl CRZ EX I drove
Technical Features
* 122-hp, 1.5-Liter, 16-Valve, i-VTEC® 4-Cylinder Engine with Integrated Motor Assist IMA®
* 3-Mode Drive System (Sport/Normal/ECON™)
* AT-PZEV CARB Emissions Rating[6]
* 100.8-volt nickel-metal hydride (Ni-MH) battery pack
* Drive-by-Wire™ Throttle System
* Cruise control
* Unit-Body Construction
* MacPherson strut front suspension
* Torsion-beam rear suspension
* Front and rear stabilizer bars
* Electric power-assisted rack-and-pinion steering (EPS)
* Power-assisted 4-wheel disc brakes
Safety Features
* Driver's and front passenger's seat-belt reminder
* Dual-stage, multiple-threshold front airbags (SRS)
* Front side airbags with passenger-side Occupant Position Detection System (OPDS)
* Side curtain airbags
* Driver's and passenger's active head restraints
* Advanced Compatibility Engineering™ (ACE™) body structure
* Anti-lock braking system (ABS)
* Vehicle Stability Assist™ (VSA®) with traction control[4]
* Electronic Brake Distribution (EBD)
* Tire Pressure Monitoring System (TPMS)[7]
* Side-impact door beams
Interior Features
* Leather-wrapped steering wheel
* Aluminum shift knob with leather
* Automatic climate control with air-filtration
* Power windows with auto-up/down driver's window
* Illuminated window switches
* Power door locks
* Tilt and telescopic steering column
* Illuminated steering wheel-mounted MID and audio controls
* 3 beverage holders
* Door-pocket storage bins, Front
* 12-volt power outlet
* Rear window defroster
* Driver's seat with manual height adjustment
* Reclining seatbacks
* Ambient console lighting
* Rear cargo console
* Cargo area light
* Cargo cover
* 360-watt AM/FM/CD premium audio system with 7 speakers including 8" subwoofer
* Bluetooth® HandsFreeLink® with Illuminated steering wheel-mounted phone controls[5]
* Textured aluminum pedals
* Illuminated vanity mirrors
* Radio Data System (RDS) (Not available on EX with Navigation)
* MP3/auxiliary input jack
* USB Audio Interface[2]
* Windows Media® Audio (WMA) playback capability[8]
* Speed-Sensitive Volume Control (SVC)
* Backlit gauges
* 3-mode drive system
* IMA charge and assist indicator
* Multi-Information Display (MID)
* Exterior temperature indicator
* Maintenance Minder™ System
Exterior Features
* High-Intensity Discharge (HID) headlights with auto-on/off
* Fog lights
* 16" alloy wheels
* P195/55/16 86V all-season tires
* Fin-type roof-mounted antenna
* Security system with remote entry
* Body-colored, heated folding power side mirrors with integrated turn indicators
* Variable intermittent windshield wipers
* Rear window wiper/washer
* LED brake lights
* Cruise control
Safety Features
Interior Features
* Power door locks
* Cargo area light
* Cargo cover
* Backlit gauges
Exterior Features
* Fog lights
* 16" alloy wheels
* LED brake lights
Next The Drive
This was a short 10 mile drive during a service appointment for Missy's Civic
I normally have this route I take which is generally 30-40 minutes but decided that since I wasn't there to buy a car and especially this one; I wouldn't take it thru my normal "run"
First off the interior is all Honda;from fit and finish to having everything right there for the driver
The shifter is better than the Civic Si and almost S2000 like although the gearing is not but this is because it's aimed at economy not canyon carving or dragon slicing as we would say here east of the Rockies
The view from the driver's perspective is very reminiscent of my beloved CRX in fact it felt a lot like the CRX only heavier
O course the CRX didn't have air bags, bluetooth AC or even a radio for that fact
I left it in sport "mode" and it chirped the tires power shifting into 2nd gear
The tires don't like being pushed hard at all but again they are low roll resistant and designed for ultimate MPG not FTD
Turn in is crisp and exiting a corner requires minimum effort all be it is slow.
I liked the navi but would never order one with it
The radio sounded crisp and clear and the idea of Bluetooth makes sense in today's world
Yes Becky that means I would upgrade my phone finally
Final thoughts
Honda has a winner here.There is a lot of JDM companies building tuner parts for this car .Anything from CAI's to exhausts to supercharger kits can be had by the end consumer.
I like the idea of the car and Honda can answer a lot of naysayers if they do a couple of things IMHO
Build a variant like an Si like they had with the HF CRX for top MPG and the Si for the sporty crowd
K20,LSD,6sp and drop the IMA battery deal and the guesstimated 100 kilos of weight
If they don't, then the tuners will
Oh and stickier tires too
Anyone have the # to Hasport ?
........never mind I found it http://hasport.com/store/
Good write-up Steve... I think the car in person looks better than it does in photos and I saw an e-mail from King already offering up parts for the CR-Z.
I think I'd like to wait a year or two to see if they will bring out an Si variant for this car... although I'd be surprised if they would drop the IMA portion based on the direction they are going..... which, in m opinion seems to be.. follow Toyota with their passanger car philosophy... eco - boxes that are designed for safety and fuel efficiency, and not fun...
What was the pricetag btw?
So the price tag is what gets me .... I just don't know how it can be worth the price they're wanting for these things?
I checked one out at immke when I was having my oil changed, I really liked the interior and design of the car but felt it was pretty pricey for what you get. That was just my initial impression though. It's very small, doesn't have much power, and the gas mileage isn't so great to warrant the price tag. Why not spend a little exta and get a civic si that has more room?
Good write-up, Steve-o.
I do like the looks of it, but I think it's very color dependent. At the Detroit autoshow, I thought the base white one was very dull and plain while the red ex looked sharp. I'd take mine black or red and put some black/graphite wheels on it (and lose some of fuel economy)
I agree that it would make a great Si with a civic si drivetrain
As for the price, there will be deals at some point. I didn't pay anywhere near sticker on my two hondas
I did some number's crunching
A 2011 Civic Si is $22,955..........0.9% @ 36mths =$645.00/mnth
A 2011 CRZ Ex is $20,760.........0.9% @ 36mths =$560.00/mnth
I wonder if Uncle Sam still has a tax credit for Hybrids ?
Honda will put the rdx motor in it, some leather and big wheels and add 10k to the price and call it an Acura.
