garage door will not open
I have a two car garage and the side that my Stook parks on will not open with any of my remotes.
It works from the key pad and also from the switch inside but not the remotes.
Its a pain in the ass opening both sides to get out, then getting out of my car closing the one door from the inside switch, then closing the other door with the remote. Too top it off when I come home I have to open the one side with the remote get out of the car to open the Stook side with the switch then getting back in the car to park
Any suggestions?
Any suggestions?
OK I have a home link on my Accord and a remote in my company car both do not work nor does the remote in my Stook how do I reprogram my remote? Can it be a prob with on the recieving end ?
Charlie, it sounds like it almost got to be at the head unit. I ran into a problem with a Sears unit last year and had to call the Mfg. hotline for help with reprogramming the unit.
You might check the head unit to see if it has instructions on it. Otherwise try calling the mfg.
Good luck,
CG
Good luck,
CG
If the remote did not come with the opener you could have the problem with rolling codes. The sears screw drive is made by LiftMaster and uses a rolling code (prevents others from scamming you code) I went through several iterations with Sears / Liftmaster until all remotes, outside key pad all worked.
