NY FS: 1999 Audi A4 Avant. 5 speed 1.8t
F/S 1999 Audi A4 Avant.
-5 speed 1.8T
-Black with gray leather interior.
-Currently has just under 179k, bought it from a friend with around 175k on the clock last February, who bought it from another friend who had it for around 3 years since 126k.
-ST coilovers.
-Interior is in great overall shape. Tear in drivers seat across seam. Small burn in rear seat. Drivers heated seat takes a while to warm up, will include replacement that was never installed. Passenger heated seat warms up extremely fast.
-Price includes A6 fat 5's which could use a refinish. Also includes wheels pictured. I've been told they are "Exclusives." Believe they are 17x8 front and 17x9 rear. I believe the 5x114.3 adaptors already on the car are pictured are 20 and 25. Sale will include giant 45mm adaptors as well. The passenger side Exclusives were professionally repaired for some curb rash in September. No bends or curb rash currently, but could use a decent polish.
-Tires are 205/45 Hankook Ventus V12. 2 have less than 1k on them, 2 more brand new ones are on order.
-Weathertech gray rear cargo liner.
-Yakima Whispbar cross bars for roof rack. There is a hole drilled through each rail on the drivers side. Hardly noticeable as it was drilled through the rubber portion running across.
-OEM windshield is cracked, never leaked. Will be replaced by Safelite prior to sale.
-S4 front bumper is pretty destroyed, will need to be replaced.
-Paint on S4 side skirts is chipping, could use a respray.
-Drivers side front door is dented. Was partially pulled out by PDR, no paint chipped/cracked though.
-Hood has dent just above grill on drivers side. Leather hood bra is included, when on the dent is not noticeable at all.
-LED interior lighting.
-One piece headlights with 6k HID low beams and Phillips X-Treme Vision high beams.
-Magnaflow catback exhaust.
-Pioneer head unit with iPod connection in glovebox.
-Redline black leather shift boot.
-No leaks.
-Play in shifter, could use a shifter bushing upgrade.
-Vibration while braking at high speeds.
-Dieselgeek skid plate that has seen some miles, but still doing it's job.
OEM rubber floor mats.
-Aftermarket rear hatch struts.
-S line steering wheel, will include stock wheel as well. Horn works, but airbag light is on. I'm pretty sure it's just do to the previous owner splicing harness for an aftermarket wheel that was installed.
All maintenance/work done by previous owner:
-35k miles on timing and accessory belts
-30k on track density engine mounts
-25k on OEM front axles
-7k on OEM S4 clutch/pressure plate/light weight flywheel. Rear main seal and clutch bleeder also changed
-4k miles on performance rear diff mount
-6k miles on brake discs/pads/rear calipers
-15k miles on B&M short shifter and tranny fluid
-25k on new lower radiator hose and newer radiator
-Replaced coolant and brake reservoirs
This car has never given me any issues in the year I've owned it. Made it to Ocean City for H2O with 3 of us in the car and cruised the whole weekend with 5 of us in there without a problem.
Located in Nassau County, NY.
Asking $5000 obo. PM me with any questions.
-5 speed 1.8T
-ST coilovers.
-No leaks.
