FS: Alpine Amp - MRP-T220 - Brand New
I have brand new Alpine MRP-T220 amp for sale. I bought it because I thought my amp was broken, but it was something else. I opened the box, hooked it up and tested it, so I know the amp works perfectly. Then i took it out and put it right back in the box. This is small enough to mount under the driver's seat.
$100 shipped and paypal'd or $80 picked up for metro members
I have the exact same amp in my s2k now and it powers my 2 speakers and 2 tweeters very nicely. I used to have the same amp in my integra to power a 10" sub. It is a great amp.
The 2-channel MRP-T220 gives you awesome bang for your buck, and sports some "extras" that you'd usually find only on higher-priced amps.
The MRP-T220 is designed to work in a variety of applications: With 50 watts RMS per channel, you can easily drive a pair of full-range or component speakers in stereo mode. Or, power a subwoofer with 140 watts when you bridge the MRP-T220 to mono. What does all that power do for you? It makes your music sound tighter and more detailed at all volume levels.
A selectable high-pass/low-pass crossover at 80 Hz lets you adapt the MRP-T220 to any job (full-range speakers or a sub) by adjusting the frequency output. If you're driving a subwoofer, the 20 Hz subsonic filter eliminates inaudible low frequencies for cleaner sound and greater efficiency.
BassEQ offers an adjustable bass boost of up to 12 dB at 50 Hz. Speaker-level inputs allow you the flexibility to hook up the MRP-T220 to just about any system, and gold-plated jacks and terminals ensure that you get the cleanest possible signal transfer.
•50 watts RMS x 2 at 4 ohms
•70 watts RMS x 2 at 2 ohms
•140 watts RMS x 1 bridged output at 4 ohms
•stereo or bridged mono output
•4-ohm stable in bridged mode
•MOSFET power supply
•10-gauge power and ground leads recommended — wiring and hardware not included with amplifier
•Tri-way capable (Tri-Way crossover required)
•high-pass/low-pass (80 Hz) crossovers, 18 dB/octave
•variable 0-12 dB bass boost at 50 Hz
•20 Hz subsonic filter
•speaker-level inputs
•gold-plated power and speaker screw terminals
•8-1/8"W x 2-7/16"H x 9-9/16"D
orangebarius
01-25-2010 11:21 AM
