New York - Metro New York S2000 Owners Owners in New York City, Long Island, New Jersey, Connecticut
Need to remove hub -- need ball joint remover
Old 12-11-2008, 09:10 PM
Spec_Ops2087's Avatar
Originally Posted by Billman250,Dec 11 2008, 09:20 PM
Tie rod puller on the left...perfect for s2k lower ball...
What about the upper one?
To sum a long story up, my wheel bearing is shot so I'm getting it replaced so both upper and lower ball joints must be popped.
Old 12-11-2008, 10:00 PM
Former Sponsor
Moddiction's Avatar
When doing my diff I used the ball joint popper and worked perfectly. Was able to swing the axle out of the way and make the job much easier.
Old 12-12-2008, 04:39 AM
minitoyota's Avatar
I believe the upper arm is pressed into the hub, although you can carefully remove it with a hammer. I would just remove the arm with the hub and bring the entire assy to get the bearing replaced. If you do separate the upper arm from the hub make sure you notice the marking for alignment, its small arrow if i recall.
Old 12-12-2008, 06:14 AM
In picture 5 and 6 you can see the ball joint is not pressed in or anything...that little L backet might be but I'm not concerned about removing that.
https://www.s2ki.com/forums/index.php?showtopic=223599
erickss13
11-25-2010 05:11 AM
kMfromLA
09-06-2004 09:34 AM
Blue2002
02-16-2003 10:47 AM
Quick Reply: Need to remove hub -- need ball joint remover
