K&N FIPK AIRCHARGER! SHIFT KNOB! SEATBELTPADS
Originally Posted by myclue,Jan 28 2007, 08:31 PM
probably not. Since hes an 06. he had to drill holes for 02 sensor. you might have to find a way to seal up the big hole.
Theres no O2 sensor on the intake. Theres one on the header (primary o2) and one thats downstream on the cat (secondary). On the intake theres a port for the PCV system and one for the air pump (AP1). I can see where the port is blocked off in Davizzles pic because his car doesnt have the air pump so im sure it will fit. But to make sure, you can just look it up in the GB forum and see if there are different part #s for each model or just 1.
it will fit. all you have to do is unplug the caplug for the air pump...the one that i blocked for my 06 and u have to plug in the hole for the AIR TEMPERATURE SENSOR. not o2 sensor. there is no o2 sensor. A rubber grommet is already in place so the hole is like 1/4 inch .....intake sold anyways..
BootsS2K
07-01-2018 05:39 AM
