Cold Weather Problem?
Since it's gotten really cold the last few weeks, on the below 40 days, everytime I started my car it would run for a few seconds, then it'll stall. I'll start it again and it'll be fine. This happen to any of you? I'm going into the 3rd year with this car and I don't remeber this happening the last couple of winters. Any ideas? Should I be worried?
I noticed that it almost stalls out when i release the clutch also.
But i tried with the fan turned off and i think it solved the problem.
Just turn on the fan when the car is running for a min or two.
Let me know if you guys have the problem after you do that.
There was a post a while ago about if you reset the ECU when its cold it fixes the problem. It had something to do with the ECU learning the new conditions outside. I don't know if it works but its worth a try. I never really drive mine in the winter so its not a problem when it does stall I just start it again.
