Clutch leak?
Clutch leak?
Got in my car yesterday morning to head out to work and the clutch was lower then normal and I couldnt get into gear. Took it around the block and the car just wouldnt get into gear. Had to shut off the car a couple times just to get it into revese just so I can put it back into the garage. I was already running late for work so I didnt even have a chance to take a look at the car
Came home from work yesterday and noticed that my clutch fluid was empty. This would be the second time in 2 months or so that I have had to fill the container with clutch fluid. Tried to search for a similar issue but couldnt find much info. Is my clutch master cylinder done? Common problem for 2000 ap1? Any information would help. Thanks guys.
sounds like the clutch master cylinder needs to be replaced. check for leaks inside the car near the clutch pedal. even look for drops underneath your car where you usually park. if it took 2 months, then its a slow leak.
thanks guys I found some master cylinders on ebay for fairly cheap. I havent noticed any leaks by the pedal, yet I'm about to go on break in a couple minutes so I'll check it out.
