New York - Metro New York S2000 Owners Owners in New York City, Long Island, New Jersey, Connecticut
Anyone know how oil pressure would go way up?
Old 07-07-2010, 06:38 AM
Former Sponsor
Moddiction's Avatar
Thumbs up Anyone know how oil pressure would go way up?
Something weird is going on. Well always is with my car but usually the oil pressure was around 10-15 at idle. I have not changed the oil or anything. Now at idle even in these ridiculously hot days the oil pressure at idle after driving for a good while is above 20 psi. Used to dip down around 10.
What could have changed to cause this? I like the pressure now but just concerns me that it changed like that. Crusing oil pressure seems to be about the same though 70-80.
Any ideas??
Old 07-07-2010, 07:16 AM
orangebarius's Avatar
after changing every part possible, do you think its the gauge?
Old 07-07-2010, 07:21 AM
Former Sponsor
Moddiction's Avatar
I mean it's possible of course. Cruising rpm's seem to be about the same though. Just idle changed.
I'm not talking about the wideband. That's a whole different story lol.
Would have thought my engine would have blown already if it was running that lean though but try to not get on it much. Couldn't resist last week had to do a couple pulls with a turbo 350z and motor didn't blow. Was running really lean though.
Oil pressure issue is brand new. I am fine with it as it makes me worry less. Just hope it is not up from something breaking haha.
Old 07-07-2010, 08:10 AM
m R g S r's Avatar
what gauge?
you didnt do an oil change recently and use a different weight oil, did you?
Old 07-07-2010, 08:11 AM
Former Sponsor
Moddiction's Avatar
Well it is a crappy glow shift one. I had the oil pressure sender go bad before but just showed super low oil pressure then. Cruising is the same as before leading me to believe the sender didn't go bad or anything since only the idle oil pressure seems to have changed.
Old 07-07-2010, 08:13 AM
m R g S r's Avatar
i wouldn't worry about it, just use the oil pressure gauge to make sure there is no drop in oil pressure while cruising, so you could save your motor from a spun bearing.
Old 07-07-2010, 08:49 AM
Former Sponsor
Moddiction's Avatar
Well yeah that is what I use it for but just weird it would jump up so much all of a sudden. Been around 10 even before I was supercharged. Now all of a sudden jumped up to where most seem to say theirs is at idle.
Old 07-07-2010, 08:57 AM
Spec_Ops2087's Avatar
I wouldn't worry about idle pressure so much...if it's going to blow, it'll blow when it's at high pressure (aka cruising / WOT / etc)
see if you and joey can get a 2 for 1 special on new motors. beating on them when something is wrong.
Old 07-07-2010, 08:59 AM
Former Sponsor
Moddiction's Avatar
hahah. How can I resist a turbo 350z lol? He kept getting a jump as I was a bit nervous to just slam it wot in vtec but then I would stop his pull each time. So must have been a base bolt on turbo kit I am guessing.
Quick Reply: Anyone know how oil pressure would go way up?
