Alignment help for lowered and staggered set up ap2
I do about 3 track days a year. Car is driven about 15000 a year. I autox about 3 days a year also. I live in ct so the roads are better than NYC. I currently have a staggered set up running rpf1s with stock tire sizes 225/17 and 245/17. I just put eibachs springs on stock suspension with a drop of about 1 inch so I am going to head over and get an alignment. I also have a saner front sway and xbrace. Would you guys recommend uk specs or something different. I don't want my tires to last only 3000 miles but it's not a huge concern if they wear out slightly faster than stock specs. Any suggestions?
eibachs don't lower the car that much to be so concerned with alignment worries IMO. I had Swift springs on my old car and never did an alignment after install and for two years of about 1200 miles a year the tires were wearing even. Swift springs lower more than eibachs so I think you will be ok. However, my car was aligned well from the start. Hope this helps..
I'm interested in the responses. I have almost the same setup and need to get an alignment soon.
AP1
Stock shocks
Eibach Pro Kit springs and sway bars
AP2 wheels
225/255 Tires
I found the camber went about -1 degree additional after the springs.
I'm thinking :
Max Caster
Front camber -1
Front toe 0
Rear camber -2
Rear toe ?
AP1
Stock shocks
AP2 wheels
225/255 Tires
I'm thinking :
Max Caster
Front camber -1
Front toe 0
Rear camber -2
Rear toe ?
Most of the literature out there is for ap1s and non staggered setups. I haven't seen too much in terms of recommendations for ap2 with staggered setups.
btw, I have an ap2 with 225/255, ap2v1, lowered alot.
Originally Posted by Conedodger' timestamp='1333552539' post='21574867
Max Caster
Front camber -1
Front toe 0
Rear camber -2
Rear toe ?
Max Caster
Front camber -1
Front toe 0
Rear camber -2
Rear toe ?
