Yo Ellmx5
Yo Ellmx5
4 wheel alignment and new front sneakers 10mm smaller and re -bedding the brakes =
I almost hit the dashboard on a test drive tonite! SWEET!
Its a whole new S
Also no more rub
Its a whole new S
Also no more rub
Originally Posted by elmmx5,May 7 2009, 06:34 AM
Congrats, I'm sure the car drives 100% better now.
Originally Posted by kenta,May 7 2009, 08:52 AM
Now you just have to replace those fender liners.
Erick
here ya go
Before
LF Camber -0.6 RF Camber -0.5
LF Caster 6.4 RF Caster 6.4 Loose caster bolt found here!!!! This was my problem!
LF Toe 0.02 LR Toe -0.06
Total Toe -0.04
Steer Ahead 0.04
LR -1.7 Camber RR -1.9 Camber
LR 0.22 Toe RR 0.22 Toe
Total Toe 0.43
Thrust Angle 0.0
Now
LF Camber -0.4 RF Camber -0.5
LF Caster 5.8 RF Caster 6.0 Bolt tightened
LF Toe 0.03 RF Toe 0.00
0.02 Total Toe
0.02 Steer Ahead
LR -1.4 Camber RR -1.5 Camber
LR 0.19 Toe RR 0.22 Toe
0.41 Total Toe
-0.01 Thrust Angle
Previous car had a twitch in certain situations, attributed to loose caster bolt! Dont know how that happened but good to go now.
Now car tracks true and alignment guy said he did try to compensate slightly for the 10" avg crown in Maine roads. Thats the slight diff we see from L to R specs.
Rear camber is back in spec it was slightly out. RR was worse previous wear tire on the car it also had more neg camber.
Extended thoughts will come when i get it out there in the future. The rub is gone and car feels a lot different.
Oh and last observation car has no extra clearance under lip or aft center of drivers door to get on the rack. Any lowering and it wont go on. Its right there touching now.
Your thoughts?
