Shifting problem.
Old 07-17-2009, 02:08 PM
  #41
lotus7racer's Avatar
Originally Posted by HARDtoTOP,Jul 17 2009, 01:49 PM
Once in a while I like to touch too!
Which big tools you want to touch?
Old 07-17-2009, 04:09 PM
  #42
ScottyBallistic's Avatar
While not common , You should check it for crank walk before you pull the tranny . Just a last minute thought as Devs2k has this issue . Granted he has a aftermarket clutch . But it only takes a minute to check anyway
Old 07-17-2009, 04:36 PM
  #43
zzziippyyy's Avatar
Originally Posted by boltonblue,Jul 17 2009, 07:32 AM
he likes to watch.
Old 07-17-2009, 08:50 PM
  #44
SI JASON's Avatar
how do you check for crank walk? thats a new one on me
Old 07-18-2009, 03:27 AM
  #45
I think what he means is crankwalk?
Movement of the crank out of stock specifications. All crank moves left to right. An excessive lateral crank movement will hit, grind and destroy the crank sensor.
I don't know what is the relation between your problem grinding gears & hard shifting.
Perhaps he can explain that to us.
Old 07-22-2009, 11:53 PM
  #46
SI JASON's Avatar
Welp took the tranny off tonight and found a broken clutch disc. the metal house around the soring broke off and was wedged in the spring lol.
Ps s2k was the hardest tranny i ever had to take out lol.
Old 07-23-2009, 03:09 AM
  #47
Glad you took the drastic solution and found the problem.
Yep! the s2000 tranny is bulky and heavy...very limited space to wiggle and to pull the housing from the spline.
Old 07-23-2009, 03:18 AM
  #48
Ah , the Glenn problem Blown disc
Ya , I did not want to mention how much a PITA it is figure it was better for you to experience it for yourself .. LOL . Hope you had a book to help you
Glad you figured it out
Old 07-23-2009, 03:22 AM
  #49
Crankwalk is when the thrust bearing is no good and the crank moves in and out . So if you push the clutch the flywheel and crank move . This takes away from being to disengage the clutch as you are not pulling on the clutch splines , but instead just moving the whole assembly .
Old 07-23-2009, 03:47 AM
  #50
kenta's Avatar
In my old car I actually had the same issue except one of the springs broke into a bunch of pieces and got lodged in various places. Driving to the shop I was able to get it in 2nd gear after ganking the level with both hands. Ended up leaving it there the entire time and took backroads.
Time for an upgrade!
Quick Reply: Shifting problem.
