Questions on photobucket
I've been using photobucket to host my pics,(thanks again for the suggestion, Steve), but I think I'm doing it the long way.
Do you guys re-size your pics before loading to photobucket? If so what size do you use?
Can you load multiple pics to your album instead of loading one by one? What about posting them. Do you copy and paste individually?
I obviously have not figured out how to use the "multiple load" option.
Thanks!
Thanks!
Lainey, It is a PITA with loading pics. Multiple upload never worked for me and I have always have to upload individually. It used to be so much easier before this damn update.
i think George is talking about s2ki and not photobucket..
in Photobucket, you can load multiple pics at once without a problem
simply click submit multiple pics. the box should be just below where you add your single pics and it will ask you how many pics you want to upload.
also - to resize, i use Image Resizer - it's a free power tool for XP. makes re-sizing a cinch -
http://www.microsoft.com/windowsxp/downloa...ppowertoys.mspx
once you have this little program installed - all you need to do is hold your mouse over the image and right click. it will ask you if you want to resize from big, medium, small and will save the photo in the place as where you store your orig. photos
let me know if you need more help
Thanks guys!
I had been using the website to load pics and had been able to use the multiple load without problem, but lately the website pics are screwed up.
I re-size before loading using "Irfanview" but the program you suggest sounds easier, Steve.
Thanks, I'll check it out and let you know if I have any questions.
Edit: I think I figured out the multiple upload. Thanks. Last question, when you post pics to the web site, do you do them individually, or is there a way to multiple load those to the web site?
not too sure i understand the question
you can load multiple images into one thread - i do this with two windows open - photobucket and s2ki
just copy the img link (third on down in your photobucket list under the picture) by highlighting the link the press and hold the ctrl key and press the C key
and then when you copy the picure link into a thread simply press and hold the ctrl key and V into the thread. you can add multiple pics into on thread by doing this BUT be sure ti hit the enter key between links
The site is working on the pics this weekend so that could be another issue BUT this is what your links should look like
[IMG ] http://img.photobucket.com/albums/ v173/Stevebass4/DSC00713.jpg[ /IMG]
hit the enter key here
[IMG ]http://img.photobucket.com/albums/v173/Stevebass4/radio-MOD.jpg[/IMG ]
and so on (in my example above i added spaces so you can see what i mean
you can quote my post above to see how the last three pics were shown
now can you please ask Rick if i am supose to break up the root things when planting geranimums after i remove them plastic thingie or do i just stick the whole root thinie in the ground they way it is
OK, I printed up your reply and will play around with it later.
Though hiding in AC today and playing on the computer may not be a bad idea.
As for your plant question.
If we understand your question.....if you bought one pot with three plants in the same pot, Rick would plant them as one, not disturbing the roots.
If they are divided into sections, as in a "six pack", then those can each go in the ground separately.
Take pics. We want to see your flowers!
OK, let me see how this works:
Anyone ever eat here?
George & Vic TWO people
Thanks Steve! Easier than the way I was doing it before!
I bought 42 single germaiums each one is in a little plastic thingie i dug a hole and poped the root thinkie out of the plastic holding pot - do i break the little square root thing up when i put them in the ground?? i just kind of separeted them - off to get a flat of impaitiens for my other section
pics will be posted shortly
Thanks for your / rick's help
Nice Picture of your garden
I really like the bushes / shrubs or whatever they are.. you guys have in the back yard!! how long does it take to get them that big??
I was thinking of lining my frt yard with those for added privacy.. and what are they??
