question about air compressors
just curious, do those of you who have an air compressor leave air in the tank after you are done or empty the tank after each use?
Originally Posted by Twiztid,Mar 15 2008, 05:38 PM
I empty mine every two weeks to get the water out that accumulates it the tank . Sometimes more often .
But otherwise mine is charged up to 120psi
I empty mine after every use, because the use is infrequent. why keep the tank under pressure for a month if I'm not using it. If I used it daily, I would probably follow Erick and Scott's approach on the theory "why run the motor more than I need to."
2 fast for u
03-16-2004 08:41 PM
