Help Asap Removing Lug
Old 12-28-2007 | 08:26 AM
JSWhaler's Avatar
Default Help Asap Removing Lug
Need some help, removing my wheels and somehow I managed to strip one of my locking lug nuts i.e. honda. How the heck can I get it off?
Old 12-28-2007 | 08:31 AM
Triple-H's Avatar
The funny thing about these wheel locks, everybody seems to think they are actually an effective anti-theft tool... Chances are you can find a garage close to you who will remove that wheel lock lug, just be sure you take a regular one to replace it with for your trip home.
I know several garages that have this tapered cone shaped tool. You put it over the lug key, whack it on with a hammer, and then loosen the key like you would any other nut. Garages have to have this tool because there are too many people in this world who A- did not know their car even had lug keys and B- can't remember where their lug key is.
Good luck!
Old 12-28-2007 | 08:38 AM
ajlafleche's Avatar
Whatever you do, don't follow this example
Old 12-28-2007 | 08:43 AM
Triple-H's Avatar
Old 12-28-2007 | 08:59 AM
Tadashi's Avatar
Can you say Red Neck?! I knew you could
Hey Bubba - watch this
Old 12-28-2007 | 09:16 AM
JSWhaler's Avatar
I'll try to figure something out. My car is currently off the road, so I'm trying to do this at home.
Old 12-28-2007 | 09:24 AM
Bass's Avatar
smash a socket over it
Old 12-28-2007 | 09:30 AM
elmmx5's Avatar
Using an air chisel in the key area at an angle usually does the trick, but that isn't an option for everyone.
Old 12-28-2007 | 09:58 AM
Cubs2k's Avatar
tap weld a bolt to the end of it.
Old 12-28-2007 | 01:54 PM
dlaio's Avatar
From experience.
Don't use a chisel. It does not work. The wheel nuts are tapered and you can never get all the nut out. I spent a day trying to get a stripped nut off my jeep. I mangled it to such a state that I ended up having to cut the wheel off the hub with a torch. Wrecked the tire, wheel and hub. I now have a policy of replacing wheels nuts every 5 years, regardless of condition. I usually never use the lock, but then I usually never have anything on the car worth stealing.
Quick Reply: Help Asap Removing Lug
