FS: Custom System
FS: Custom System
*Custom Amp rack wrapped in carbon fiber style 2x2 weave, leather
*2 Alpine Type R subwoofers 10"
*1 Rockford fosgate P3002, 2 channel amp
*2 Rockford fosgate P3001 mono amps
2 mono amps, one for each sub, 2 channel up for the speakers, amp rack for a clean look!
All wirings is routed under the amp rack for a clean look, no wires can be seen.
Pics:
Subs are in MINT PERFECT WORKING CONDITION, it was hard to take pics because its under the amp rack in a custom box i bought.
All you need is a box to go into the trunk where it sinks in the middle.
P3002 specs:
-2-channel car amplifier
-75 watts RMS x 2 at 4 ohms (150 watts RMS x 2 at 2 ohms)
-300 watts RMS x 1 bridged output at 4 ohms (4-ohm stable in bridged mode)
-variable high- and low-pass crossovers (40-400 Hz at 12 dB/octave)
-variable Punch Bass (0-18 dB boost at 45 Hz) with wired remote
-Tri-way capable (Tri-Way crossover required)
-MOSFET power supply and output devices
-CEA-2006 compliant
-preamp-level inputs
-preamp outputs
-fuse rating: 40A x 1
-8-gauge wiring kit with a 40-amp fuse recommended
Pics:
P3002 specs:
-CEA-2006 compliant
-preamp outputs
I would also post or add links in the sticky FS thread above that way it will be easier if someone wants to find this thread and it left the first page . I would do it for all your forsale threads
