Dyno Shop
Dyno Shop
I spent Monday with my EP S2000 doing tuning on the dyno at Xenocron in Hillburn, NY. I know NY is not New England, but for those in CT Hillburn is near the intersection of I-87 and I-287 and is an easy trip. I am building an EP car for SCCA regional and national racing. I installed a Haltech Pro Plug-in ECU (also purchased from Xenocron) and it had to be tuned to work best with the modifications made. Xenocron is a small shop, but they did a great job and we got 230 max HP at the wheels. Chris Harris there has an S2000 and knows the cars well. I have had other cars on dynos in CT, but the Xenocron set up was the best set up that i have been to. Joe
Every dyno is going to give different numbers. I did not take the time to do before modification testing. As a comparison, Chris' AP1 with a Haltech ECU had 217 max hp on this dyno. He later put an AP2 motor in the car and had 252 HP max. Attached is the dyno chart from a couple of my runs. Unfortunately there was a misfire on each of these plots, so they don't look nice and clean. Also, the left vertical axis is labeled as Flywheel Power, but this is a chassis dyno and I was assured it was Wheel Power (HP). Joe
With AFRs like that I rather pass .. Leaning out the car is not the right way to make power in the S2000.Having said that .. the numbers are possible NA .. we have had alot of the same results
What type of Dyno? what is the correction factor? what is the smoothing factor? your dynosheet is very uninformative, Typical of Dyno Dynamics Dyno's
You have a plot with the TQ curve on it ???? that is where the most is to be gained, as much as 20ftlbs down low
Yes, it is a Dyno Dynamics dyno. I did not keep track of the correction and smoothing factors. Chris may have them in my file. I am comfortable with the AFRs. We tuned using 93 octane, but I will be using race gas. We programed in corrections for high IATs, and coolant temps, too.
Attached is a graph with torque, but this was from earlier runs, before tuning was completed. Yes, I should have asked for more graphs, but Chris has them if I want them.
EvasiveMotorsports
04-23-2014 10:56 AM
maplevalleys2k
12-10-2010 05:23 PM
mingster
05-04-2002 02:12 PM
