driveshaft spacers?
driveshaft spacers?
hey was just reading that when you lower a car that is RWD you should add a spacer to release strain on the drieveshaft...
is this true!!
is this true!!
Yes, it messes w/ the rear geometry creating undue stress and wear on the drive axles. Not an absolute necessity but something to consider and watch for.
Originally Posted by paivag,Oct 11 2006, 11:51 AM
I remember that on 4x4 lifts but not on lowering cars. I don't think you would have that much of an agressive angle on the shaft to require a spacer.
All depends on how much you drop it .
1" would not worry about it .
2" would recommend it .
As the 4X4, the S shafts are almost straight on stock suspension .
When you lower the car it has the same effect on the axle as lifting the truck . Both stretching the axle out .
