Diagram of the AP2 front lip
Could any one guide me to a drawing of the different front bumper of an AP2 and front spoiler. Didn't know that the bumper and front spoiler has to be the same year. Dumb mistake after it was already been painted and put on. Wanted to get everything put back perfect but is the little mistake that cost so much to fix. Any help would be appreciated,.,
Will my AP2 front spoiler does fit on my AP2 bumper but the thing is that my AP2 bumper is an 04 not sure and the front lip spoiler is an 05 so there are some part that doesn't line up for the bolt up.
It is made the same for all AP2 cars.
Did you get the lip used? there is an installation kit that comes with the lip. It contains retainers that you use after you drill new holes in the bumper to line up with the holes in the lip. You do not need the installation kit thoigh.
Once you fit the lip against the bumper, mark the bumper where the holes in the lip are. Drill these holes and put some toggle bolts in there. It will work the same.
nope your bumper and lip will fit if you just have to "work" it I was only thinking if you had an ap1 lip or bumper they will not fit. other thing you may want to try is since the lip is used, to use a heat gun if it isn't lineing up right, it could have twisted from sitting around for a while off of a car, polyurathane is know for doing that
It fit perfect it just that the bottom lip tab which are the 2 on the each side doesn't line up to the bottom of the bumper..I guess I have to do some new drilling on the bumper
That the thing is all AP2 04-08 bumper the same and is all the 04-08 front spoiler the same as well? Because on the installion instruction I didnt see any drilling for new hole. The 2 center tab line up perfect but the other 4 tab doesn't line up with the tab of the bottom of the bumper.
